Displays information about SNMPv3 target addresses.
| hex_addr_name | Specifies an identifier for the target address. The value is to be supplied as a colon separated string of hex octets. |
| addr_name | Specifies a string identifier for the target address. |
N/A.
Use this command to display entries in the SNMPv3 snmpTargetAddressTable. If no target address is specified, the entries for all the target addresses will be displayed.
To view the source IP address, use the show management command.
The following command displays the entry for the target address named A1:
show snmpv3 target-addr A1
The following is sample output from this command:
x670.25 # show snmpv3 target-addr Target Addr Name : v1v2cNotifyTAddr1 TDomain : 1.3.6.1.6.1.1 TAddress : 10.120.91.48, 162 TMask : Timeout : 1500 Retry Count : 3 Tag List : defaultNotify Params : v1v2cNotifyParam1 Storage Type : NonVolatile Row Status : Active Target Addr Name : v1v2cNotifyTAddr2 TDomain : 1.3.6.1.6.1.1 TAddress : 2001:0:0:0:0:0:0:5, 162 TMask : Timeout : 1500 Retry Count : 3 Tag List : defaultNotify Params : v1v2cNotifyParam2 Storage Type : NonVolatile Row Status : Active Total num. of entries in snmpTargetAddrTable : 2
This command was modified in ExtremeXOS 11.0 to display a list of tags if more than one was configured and to display the timeout value for the entry in the snmpTargetAddrTable. This command was also modified to support the hex_addr_name parameter.
